Xbox DivX?
Discussion in 'Xbox Forums' started by chrislad, Jul 14, 2005.
  1. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    I'm getting my Xbox modified next week, as I basically want an all in one media player.
    Anywho, I read that it can play DivX movies. Can they be run off a DVD, or do they have to be installed onto the HD? Also, what program do I need to view them, and would WinSCP do for ftping into my Xbox? Thanks.
  2. Drogo
    Drogo
    Dec 13, 2003
    289
    English Riviera
    Hi chrislad,
    Got grab yourself XBMC, Xbox media center, its a free download in the new groups... weighs in at about 47mb, thats all - tiny .. but works wonders .... This once installed on your xbox will be able to play everything you throw at it - although to be honest its not good at playing DVD movies... but again there's a app called dvdx for that ..
    Back to XBMC, this will play xvid, divx, svcd, .bin files .. quicktime, everything pretty much and the front end is second to none ...
    I have my main xbox linked to my Plasma, with a 200 gig HD in it - on here I store lots of things... Xbox is also linked to my PC in my loft/office and I stream movies from shared drives on my PC's ....
    If you can link your Xbox with your internet connection, then its well worth doing so, as you can also use XBMC to stream latest game trailers, movie trailers, radio and so much more ...
    All in all just a first class product that many people on the scene have help put together ....
    If anybody were to say to me, about getting a media center - I would say Xbox and XBMC
    Hope this helps
  3. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Thanks Drogo. I have a wireless network in the house. Can the Xbox be set up on that if I get a wireless adapter for it? I only got a 40gig HD for the Xbox, but I'll probably update that if I need to.
  4. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +286
    Yep - it's pretty much the ultimate 'media centre in an easy to use box' although to be fair, setting the whole thing up can be a pain.
    The guys who chipped mine with a SmartXX chip couldn't install anything other than the actual hardware (covering their butt for legal reasons) so I had to hunt down all the various proggies needed and figure out how to install them. I know a bit about software installation professionally, so I managed to get it done in 4-5 hours (from knowing nothing). If you were just a regular gamer with minimal computer knowledge it would be a right PITA.
    Anyway, now it's done I'm amazed at just how great the Xbox is as a media centre. It's interesting to see what MS have done with the XBox360 as they are almost copying all the features of XBMC. Of course, the 360 will only act as a client to a PC with XP Media Center Edition on it, so it STILL isn't as good as an original Xbox that's been chipped!
    Gav
  5. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Well, I'm fairly well versed in computers so setting up stuff shouldn't be a problem, and if it is, I really should study some more.
    Hell, I'm doing basic factory work for the summer in DELL and I'm fixing PCs here left, right and centre.
  6. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    For a simple to use all-in-1 installer go to www.x-disk.com where you will find a good selection. There are usefully bit torrent links for downloading the ISO images too.
  7. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Well, I should have my Xbox back to be during the week.
    For FTPing into it, I assume a crossover cable and WinSCP will suffice?
  8. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,173
    +26
    Hi mate the best way to install XBMC + all the other software you would use with your xbox, is to install somethen called deluxe auto installer or even slayers auto installer.
    In short words these programes will auto install all the software you would need all at once, with out having to FTP to your xbox...... + spending hours trying to hunt all the software progrmaes down.
    you will find slayers on any P2P programe like emule > limeware etc... I recomend you use MIRC thou and connect to a server calles xbins.
    enjoy !
  9. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    All the stuff I need is being installed for me anyways. I will need to ftp in if DivX files can't be run from a DVD, plus I'm going to be updating my copy of Pro Evo 4 with real jersies and the like, so I need to copy that onto the HD and ftp the replacement files over.
  10. mitch
    mitch
    Sep 6, 2003
    5,254
    +604
    burn divx files to dvd as an iso and then play on xbmc.you can also stream them from your pc :thumbsup:
  11. chrislad
    chrislad
    May 6, 2005
    5,808
    83
    Rep. of Ireland
    +143
    Yunno, this is turning out to be the best 120euro I ever spent. :)
    (Xecuter 3 chip + installation, as I can't be arsed, and I don't want to risk it)
