Xbox deal in Virgin
Discussion in 'Xbox Forums' started by captaindobie, Jul 10, 2003.
  1. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    X Box (including Green with 2xS controllers) available from Virgin for only £109.99. 5 days only mind...:smashin:
  2. MalcolmD
    MalcolmD
    Jun 13, 2002
    84
    Plymouth
    +5
    Thanks for letting us know as my son has been waiting to spend the money he has saved.
    Just one thing though are you sure it comes with 2 controllers as our local store is only supplying one.
  3. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    Hi MalcolmD
    The original black XBOX is supplied with only 1 controller.
    The limited edition translucent green XBOX is supplied with 2 matching 's' controllers. (It is packaged in a white box).
    There should still be stocks of this around, although not every store will have them.
    Hope you are lucky...
    Try this link for more details.
    www.xbox.com/uk/hardware/limitededition.htm?cs_catalog=cat-uk
