Xbox Crystal - Laptop
Discussion in 'Xbox Forums' started by Rikwaller, Aug 18, 2005.
  1. Rikwaller
    Rikwaller
    Mar 21, 2005
    2,456
    +144
    Sorry about the noob Q's..... (everyone starts somewhere) !!
    I have an X box Crystal and was told it had a larger hard drive that the standard xbox. Is this true ?
    If so is there anyway I can use the hard drive for storage ? via Network ?
    I have had a search and cannot find any answers :(
    Thanks for your help
  2. c.jelly
    c.jelly
    Jul 12, 2005
    222
    +3
    Even if it is bigger, the only partition you'll get hold of is 8GB. But as far as I know they're all the same size.
  3. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    if its modded, it can have anything upto a 250 gig hd (or maybe bigger) the new dashboard should tell u the size
    if its not modded, it can either be 8gig or 10 gig in size
    regards
    jason
