XBox Controller - noisy??
Discussion in 'Xbox Forums' started by janmars, Jul 27, 2004.
  1. janmars
    janmars
    May 4, 2003
    162
    Just got an XBox with the official S Controller, and noticed that everything the rumble feature kicks in the controllers becomes very noisy. It sounds exactly like having loose bolts or screws in a vibrating piece of metal...quite high pitched. (Not at all the same low noise that comes from the PS2 or QC pads). So is this normal...or do I have a duff controller?
  2. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    I have 3 S-pads not one is noisy, but i also have the house brick one as well, when that rumbles all the buttons rattle and it's very noisy. i'd say your S-pad is duff take it back and swap it.
  3. anephric
    anephric
    Mar 23, 2002
    1,048
    Derby
    +147
    My S's and the Brick all make a horrible buzzing noise when the piezos vibrate: they are truly naff. If you're playing a game with the volume down it sounds like someone (cats?) drilling inside your joypad.
  4. alastair
    alastair
    May 11, 2004
    53
    Northumberland/York
    My S pads are usually fine but throughout Midtown Madness 3 while moving there is a constant whirring of the motors which is very annoying!
  5. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    yup, it's common with both types. my 's' and my neighbours old full size pad both make that sound.
  6. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    I thought it was just mine! Glad it's a common "feature"!!
    K.
  7. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    Cats with drills, eh? Ooh... err... :eek: :(
    I knew that they were about to take over the world. We're doomed, I tells ya. Doomed!
    Er, did they set a date?
    Oh.
    Hmm.
    Xboxen. Pads.
    Yup, most certainly a feature - though I've always found the older design of pad to be a touch louder. Still, when such things 'annoy' it's sometimes best to take my friend's advice...
    Well, it's a kind of solution... :laugh:
