Xbox Controller for use on PC gaming
Discussion in 'Xbox Forums' started by UncagedTyphoon, Oct 17, 2003.
  1. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    This how its done
    :lesson:
    get your self a spare fly lead for an xbox controller
    yes this is the small lead which connects Xbox to main controller lead
    1. cut off Xbox plug and strip back the outer cover
    2. get your self a usb lead for any pc device and cut off the
    device end leaving USB on lead strip back outer cover as on fly
    Fly lead (could be best to use official microsoft )
    3. You should now see that all the colours are the same on the
    individual wires except the yellow on xbox which you dont
    need as this is for the head set
    4. join all the wires colour to colour and tape and join or some
    thing (Colours may differ if using a cheap usb lead)
    5. Right now all you need is the Xbox ctrl driver for pc which is
    on the web and is downladable
    6. configure joypad as you would if using a shop bought
    Joystick for PC and your up and running now you have a
    Xbox controller for PC and just detach fly lead and put new
    one back on and back on ya Xbox
    I have been informed that this works well on halo for PC
    Anything you do to your own equip I cannot be held responseable for
    :clap: :hiya: :smashin:
  2. Sinzer
    Sinzer
    May 25, 2002
    5,794
    +1,108
    Sorry to be dull, but why on earth would you want to play Halo on a PC with an X-Box controller?
    I can understand the use of controllers for arcade games and emu's (which I use it for) but for an FPS no controller can match the old keyboard and mouse.
    Good guide though, thanks :) Alternatively you could buy a premade converter http://www.whitedog.co.uk/catalog/product_info.php?products_id=322 for a tenner :)
  3. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Good point Sinzer
    just heared some guys talking about this on live
    and thought it would be a topic some one might be interested in
    or want to do ETC
    as for me I dont play games on PC
  4. mr chadwick
    mr chadwick
    yo jim,
    you got pro evo 3 yet mate?
