Xbox controller extension...
Discussion in 'Xbox Forums' started by saibot, Nov 16, 2004.
  1. saibot
    saibot
    Jun 28, 2004
    1,231
    Near the Lee - Ireland
    +42
    Would like to have xbox setup in one room, and be able to connect it to a projector (which of course, would have to be in another room), probably about 4 metres away. So apart from using a wireless controller (which might not work due to some solid walls), does any-one know if there are any limitations to using 2 or 3 controller extension leads to connect controller to xbox ???
    ta,
    d...
