Xbox controller extension cables?
Discussion in 'Xbox Forums' started by Bonesy, May 17, 2002.
  1. Bonesy
    Bonesy
    Feb 22, 2002
    1,170
    Wiltshire
    +37
    Hi, anyone found, bought or tried an xbox controller extension cable from a UK based shop?
    I see goblin direct and gamer.uk seem to have them, but they do not appear to be branded.
  2. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    Blimey - how far away from the console are you playing. Thought those XBOX cable would cater for anything!
  3. JBT
    JBT
    I obtained 2 of the cables advertised by Goblin. I threw away the packing so don't remember if the brand, I don't see anything on the cabl.
    They seem well made & work fine.
    I can now play Halo on my projector / surround setup
  4. Bonesy
    Bonesy
    Feb 22, 2002
    1,170
    Wiltshire
    +37
    JBT, thanks for the response, I'll go for them.
    Ashearer, about 18 foot away from a 9 foot projector screen,
    in the middle of a 6.1 system ;)
    shame I'm so cack at halo :(
  5. Bonesy
    Bonesy
    Feb 22, 2002
    1,170
    Wiltshire
    +37
    Cheers JBT, my problem arises around the fact that many of these makes are being withdrawn/re-called, so I'm wondering about the quality. Might give goblin a try.
