XBOX connections
Discussion in 'Xbox Forums' started by hornydragon, Apr 21, 2002.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Is it possible to optical Audio out of an XBOX while having composite video through an RCA socket (phono). Odd question but I need the answer ASAP. As my amp will only switch composite video and my TV has only one Scart socket. Taken up by Amp video out.
    Also what does a streched 'n' with 3 dots above it mean? My TV has this as one of its input options but nothing seems to work on it.
    Cheers HD:confused: :confused:
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The ^ with ... above it means that input will accept an RGB video signal, from such sources as DVD or a Digibox.
  3. Jason S
    Jason S
    The advanced AV pack gives you S-Video, Composite, Optial Out and Phono out for audio.
    try www.mx2.com for the cables, I had to wait about 2 weeks for mine.
