Xbox connection problems
Discussion in 'Xbox Forums' started by sjl, Apr 29, 2002.
  1. sjl
    sjl
    Jan 1, 2001
    81
    Ok I just brought an Xbox on saturday and only managed to play Halo for an hour :( .
    Didnt get a chance to use it yesterday but I did manage to buy a Joytech optical cable :) so I rushed home tonight from work to plug it in and have a session in 5.1 to only spend the last hour trying to figure out why I cant get proper 5.1.
    Please correct me if I am wrong here but this is how I have connected it up to a Sony STRDB930 amplifier.
    I have taken the optical input from the Xbox to the TV/LD in on the amp.Is this correct?I do not get the blue indicator come on when I start the game.I also have tried changing the settings on the Xbox as well.
    Oh yeah also tried fiddling with the amp settings without much luck.
    Any help appreciated as I need!! to play some Halo :D
    Thanks guys
    Steve
  2. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    at a guess - properly check that you have surround sound option enabled on your xbox main settings.
    secondly, I used tohave a 930, make sure you have the right audio input selected, ie. optical.
    Thirdly, try setting it manually to 5.1, and check the rear speakers/sub, there may be a problem auto-detecting.
  3. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    I am guessing you haven't changed the sound options in the XBOX set-up screen.
  4. kenjolly
    kenjolly
    Mar 11, 2001
    101
    Blackpool
    +5
    had a similar problem (I have a 930 as well). TV is connected using analogue and XBOX optical is connected in the right hand side optical in (DVD in the left hand side).
    Had to change the input for the TV device to AUTO as it was set to analogue (which meant it ignored the optical input).
    To change it set the device to TV, under the flap there's a button called 'input' - ensure this is set to auto. Hopefully that should do it (assuming XBOX is set to DD).
    Kenneth
  5. sjl
    sjl
    Jan 1, 2001
    81
    Thanks guys
    It was my fault I had not set tbe Xbox up properly doh!!
    I owe you all a beer :D
    Steve
  6. john87
    john87
    I was gonna tell you to go into the XBoxs' menu set up but you said this
    so I assumed you would have done that.
  7. Bonesy
    Bonesy
    Feb 22, 2002
    1,161
    Wiltshire
    +29
    John87, trying to win yourself a free beer?;)
