Xbox connection PC monitor?
Discussion in 'Xbox Forums' started by rigman, Jun 20, 2004.
  1. rigman
    rigman
    Dec 14, 2000
    2,760
    83
    East Yorkshire
    +59
    is there any way to connect an xbox to a LCD 17" PC monitor with HD15 and DVI in connection?
    Would save me buying a separate TV with all the space saving benefits.
    thanks for any help
    Darren
  2. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    Your two options would be an external scaler/de-interlacer (though not all boxes do both) or a PC TV card (preferably using s-video input) and Dscaler software.
    Not knowing which option to take or having enough information to hand, I recently decided to try the TV card option first. Of course, it isn't 'perfect'; but I play the games occasionally, not analyse the picture 24-7! Hmm, perhaps I'm in the wrong forum... :laugh:
    Just as I was close to deciding on which of the TV cards I was going to buy, 'an offer that I couldn't refuse' :suicide: arrived on the forums. It's the best few :beer: tokens that I've spent recently - and as I come to terms with yet another one of Dscaler's functions, it gets all the better. By the way, this is with a really nasty cable that gave a truly terrible picture when tried (once!) on my TV. Despite all the potential 'flaws' (poor cable, image scaling, TFT screen), I'm really pleased with the result.
    For thirty-ish pounds (brand new), it's gotta be worth a try, right? :smashin:
    Should the scaler be of interest, a search for Briteview and/or ProV should garner a fair bit of info. There are at least a couple of alternatives, but as the available models were being updated at the time of my last looking, I can't provide much info.
    A look here and here will give you a few options.
    I've also noticed the cyclic reappearance of three possibilities in a 'Today Only' here.
    Finally, I should add that although I haven't seen the results from an external box, I'd be surprised if they hold much of an advantage (if any!) beyond the myriad configurations of Dscaler and a compatible TV card. If you have a reasonably powerful PC (with an AGP graphics card), as I said, it has to be worth trying. I'm glad I did! :thumbsup:
  3. DDRUK_Lawrence
    DDRUK_Lawrence
    Apr 29, 2004
    34
    Lik-Sang have a range of Xbox to VGA. Check here
  4. rigman
    rigman
    Dec 14, 2000
    2,760
    83
    East Yorkshire
    +59
    Just what I was looking for
    thanks guys, I appreciate your time :smashin:
    Darren
  5. M0T
    M0T
    Jan 27, 2002
    141
    +5
    This is the one you want: http://www.lik-sang.com/info.php?category=222&products_id=4233& as it takes the progressive scan signal and converts it to VGA rather than the other boxes (Apart from the £100 jobbies) that take the interlaced signal and deinterlace it as well as converting to vga, resulting in a worse picture, however the prog scan jobbies only work with prog scan games, which is quite a few to be fair but you'd be sacrificing compatability for image quality.
    I have done my VGA conversion slightly differently, I have a bios for my modded xbox that causes it to output native VGA, which produces a stunning picture, however it is not worth playing on my LCD monitor since the output resolution is 640x480 (as will all boxes regardless of type) which is far less that the monitors native resolution, so I only use it on a crt. If you want to produce a similar effect set your desktop resolution to 640x480 and check out the blurries.
  6. peve3
    peve3
    Aug 14, 2002
    436
    I gona say the only VGA xbox lead you need is http://www.x2vga.com/
    Its by far the best, by a long long way.
  7. bodyfodder
    bodyfodder
    hi peeps.
    Im thinking of connecting an iscan ultra to my 22" PC monitor for all my games consoles. What kind of picture quality would i be looking at on the monitor if the iscan is being fed an interlaced picture?
    Thanks. :)
