Xbox connection advise
Discussion in 'Xbox Forums' started by Jasoon, Mar 25, 2002.
  1. Jasoon
    Jasoon
    Can anyone advise me on the way to go as regards connecting my xbox to my TV?
    Currently my av1 (RGB, AV) has a RGB only scart from my DVD player
    Av2 (AV S-video) has my xbox plugged into it using a saitek component scart cable
    Av3 (4 pin S-vhs, RCA jack) RCA jack from my av. amp.
    The xbox looks about the same in AV1 or AV2 but the DVD player doesn’t look as good plugged into AV2
    I was originally going to buy the Official Xbox Advanced Scart but after looking at my TV’s spec I’m thinking that maybe S-video is the way to go.
    Any help would be appreciated.
    Jason…
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,538
    WEST MIDLANDS
    +1,425
    Looks like you are only getting composite from the XBox at the moment, So i would definately change to a S-Video connection using the Advanced AV pack (if you can get hold of one).
    Cheers Carlos
