  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
XBOX component
Discussion in 'Xbox Forums' started by Cornelius, Feb 11, 2003.
  1. Cornelius
    Cornelius
    I'd like to use this with my PJ.
    Does anyone know of a cable that includes optical/coaxial digital out?
    If not how are you getting 5.1 sound when using component???
    Am I missing something:confused:
    CKA
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    You can import the MS hidef kit from:
    http://www.tronixweb.com/
    Or look on Ebay, alot of places sell the monster cable that has 5.1 optical support built in also.
    Note- with a PAL Xbox you will only get a 480i image.
    Regards,
    Neil.
  3. Cornelius
    Cornelius
    thanks Neil.
    I'll have to put up with 480i in order to keep XBL unless you know otherwise;)
    CKA.
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Buy a US Xbox - it really is worth it.
  5. NeoBlade
    NeoBlade
    The Xbox can also go up to 1080i... But then you need either a modified PAL Xbox or a US Xbox. So far I think only SegaGT supports this ultra high mode. I've yet to test it as I don't have a suitable display...
  6. leedsfireman
    leedsfireman
    Mar 21, 2002
    1,191
    38
    +3
    Is there a uk supplier of the hi def pack. At moment i'm using a Games Master one but i am getting a double outline when in prog scan, i think some one else complained about the same cable not so long ago.
    Andy.
