Xbox, Component vs RGB
Discussion in 'Xbox Forums' started by jerkyboy, Dec 28, 2003.
  1. jerkyboy
    jerkyboy
    I am considering buying a TV with Component inputs mainly for use as a games telly with my Xbox.
    Is Component better than RGB ?.
    Is Progressive scan that much better ???.
    I have always found that the Xbox via RGB scart is a bit on the soft side, does component sharpen things up ???
    Any feedback would be appreciated.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    It sharpens it a little with progresive but component without progressive is mostly the same as RGB. You'll need a US Xbox [or a chipped one] for progressive scan on Xbox.
  3. Spoonman2
    Spoonman2
    Dec 28, 2002
    2,576
    87
    Ashford, Kent
    +155
    Yes, component definitely sharpens it up, quite a bit m8.
    A well worthy purchase :)
    Spoony.
  4. jerkyboy
    jerkyboy
    What set have you got Spoonman2
    I am considering the Panasonic 32PD30 which has Component and is Progressive scan combatible.
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +373
    I play my xbox games on a 19" LCD and ComponentPS certainly makes a very good difference.
    I know what your saying "how can u tell on a 19inch monitor"
    because I play sitting in my Computer Chair at about 2feet away
  6. daveymacca
    daveymacca
    I've got a toshiba 32ZD26P. I had a PAL XBOX and thought the RGB picture looked a bit blurry so bought a Microsoft HDTV pak from the states and was very disappointed as i thought it looked worse than RGB, so bought a US XBOX, using component leads with this produces an overbright image on 480i setting but select prog scan 480p setting and it looks awesome but your TV/Display needs to support prog scan to enable this option. So what I'm trying to say is if your TV doesn't support progressive scan you will not get a better picture than an RGB lead so don't waste your money on a high def pak.
