J
jcrookes
Just received my Xbox Hi-Def pack and tried it with my non-modded UK Xbox, but Im seeing disappointing results through my Sony HS20. In fact, the projector is handling composite better!
The best way to describe it is horizontal shearing. Imagine a diagonal white line on a black background, with the line running from bottom left of the screen to top right. Instead of the nice smooth line I get with composite Im getting a saw-tooth effect.
The information menu screen describes the composite video signal as VIDEO/50, while the component signal is 575/50i. I do plan to mod my Xbox, and I know as it is now itll only do 575/50i, but I was still expecting better results than this.
This effect is most apparent when DDE is set to Progressive or Film, but it still there when set to Off. Either way, composite looks better! Assuming its an interlace problem, I think the HS20 should be handling it better than it is.
Anyone got any thoughts on what Im missing and how I can improve things?
Cheers,
Jon
Cheers,
Jon
