Xbox Component Problems.... HD has stopped working
Discussion in 'Xbox Forums' started by Macca2000, Apr 25, 2007.
  1. Macca2000
    Macca2000
    Hello All,
    I've got a modded (chipped) Xbox which I have been quite happily using in 480p for the last 5 months with one of those 3rd Party HD-Component boxes from Ebay.
    Then last week I turn on the Xbox and don't get any picture.
    I check the connections - fine, then the cables - again fine. Try connecting directly to the TV (instead of using the Denon 3805 as a component switch) still no joy.
    I concluded that the the HD-Box must be stuffed so I bought a genuine MS one (complete with cables) and it still doesn't work.
    Every thing works fine using a composite connection (default cable supplied with the Xbox and when using the HD-Boxes the optical sound is still be outputted.
    I've even tried hooking up to a plasma at work today to see if my TV didn't like the signal for some reason, but again it still does not display a picture.
    Anyone got any ideas on what might be wrong? I'm fresh out :(
    Thanks for taking the time to read this.
    Macca
  2. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +68
    Long shot but have you checked the EPROM is set to NTSC and not PAL?
  3. Milamb
    Milamb
    Jun 24, 2005
    711
    Scotland
    +33
    Macca2000,
    Not to kick a man when he is down or anything but if you fancy selling the new HD box with compnent cables ( assuming that you do not need them any longer ) then please PM me. Thanks.
    I personally would delete enigmah from the box and start all over again. Possible it maybe corrupted or moved?
    Good luck - Milamb
    :smashin:
  4. Macca2000
    Macca2000
    It is definitely set to NTSC and not PAL....
    I might try taking the chip off tomorrow.
    Macca
