Xbox component lead
Discussion in 'Xbox Forums' started by Throttle, Oct 18, 2004.
  1. Throttle
    Throttle
    Sep 28, 2004
    1,821
    Leigh
    +107
    Ive recently bought a cheap xbox component lead for my non-modded pal xbox but it seems to give a pixel looking edges on when i use it scart seems better quality.
    Im guessing its down to being a cheap lead or maybe the fact i cant select higher resolution that usa and modded xbox can or does anyone have this problem on the proper M$ high defintion lead or a decent quality lead.
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    you wont get any increase in quality to be honest just from using a component pack. Best bet is to try and get it region changed.... Dont need to spend on getting it modded if you dont want.
