XBOX Component Cable
Discussion in 'Xbox Forums' started by fozziebear39, Mar 20, 2003.
  1. fozziebear39
    fozziebear39
    Jan 3, 2003
    1,009
    Newton-le-Willows
    +49
    Has anyone used the Official HD AV Pack with Component Out and Optical Audio Out on a UK Pal XBOX?
    Not sure if it works. Want to order that and the Gamecube one from Lik-Sang (Unless someone knows who has them in UK). Need to connect them all to my projector!
    :cool:
  2. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    The cable will work, but you won't get progressive scan out of it. Prog scan is disabled on both the UK Xbox and Gamecube.
  3. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +320
    Fozzie,
    UK Gamecube doesn't do prog scan either.
    I have a RGB scart to Component converter box. Scart lead from console goes into converter and out comes component leads into projector. Probably cost about the same as the individual cables.
    If you get a scart switch box you won't have to keep unplugging and plugging things as well.
    Justin.
