XBOX component Cable - Advice Please
Discussion in 'Xbox Forums' started by Santy, Oct 31, 2004.
  1. Santy
    Santy
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    the link you show has an RGB SCART cable + s-video
    no mention of component anywhere
  3. Santy
    Santy
    Does a component cable exist, saw this and got excited at optical out for 5.1 sound on 3805 amp (drool drool)
    Do any better cables exist for XBox for pic quality or will this be good going into my Denon?
    Bit new to all this...
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
  5. Santy
    Santy
    CWIC
    Thx m8, will review and maybe buy, do you use this cable, know anyone who does?
  6. Spoonman2
    Spoonman2
    Dec 28, 2002
    3,236
    107
    Ashford, Kent
    +440
    Hi m8,
    I use that cable for progressive scan component wise, and I also use the optical out for 5.1.
    That`s the lead to have in my opinion :cool:
    Spoony.
  7. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    I use one of those cables with my 3805 and have no complaints at all :)
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Gamester and monster do them as well IIRC.
  9. gwc
    gwc
    Oct 21, 2003
    499
    Wokingham, Berkshire
    +7
  10. thfccambs
    thfccambs
    Jul 17, 2002
    23,952
    White Hart Lane
    +6,898
    Wouldn't be piontless buying a hi-def av pack if you had a pal x-box?(unless it was modded)I thought you had to have your box set to NTSC to recive hi-def TV?.
  11. gwc
    gwc
    Oct 21, 2003
    499
    +7
    I want to connect the X-Box to a projector via a Lumagen Scaler, which has component in.
    gwc
  12. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    The Hi Def kit works with PAL xboxes but you will not get prog scan.
  13. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    If you have a modchip fitted, you can switch to NTSC to get prog scan
  14. gwc
    gwc
    Oct 21, 2003
    499
    +7
    What's the best modchip to get and does it just provide a prog scan output.
    gwc
  15. xavk1
    xavk1
    Aug 9, 2004
    590
    28
    +36
    There are many mod chips to choose from depending on what you want to do. Cheaper ones will allow prog scan in XMBC (once you switch to NTSC which you can do with Enigmah Video Switcher), whilst more expensive ones will even enable HDTV in the OS as well. There are also LOTS of other features that can be very useful depending on what you want to do (ie play games for either xbox or emulation etc). Have a read of this web site (check out the tutorials):
    http://www.xbox-scene.com/index.php
    This is also very worth checking out:
    http://www.xboxmediacenter.de/
