xbox 'coded' instead of 'modded'
Discussion in 'Xbox Forums' started by zamwessell, Feb 2, 2005.
  1. zamwessell
    zamwessell
    Jan 2, 2003
    1,164
    +94
    Does anyone know if an xbox can be 'coded' and what it means?
    Some guy i know says he can get the xbox 'coded' instead of 'modded'.
    I have never heard of this before.He seems to be saying that you do not need to install a chip.
    Thanks.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,127
    Canterbury, Kent
    +731
    Erm, what do you want the xbox to be able to do, besides play games? if you want to use you xbox as say a media centre then you will need it 'chipped'(modded) if you just want high-def then a soft mod will do.
  3. zamwessell
    zamwessell
    Jan 2, 2003
    1,164
    +94
    I just wondered if an xbox 'coded' would be the same as having one 'modded'...giving the full features of a mod chip.
    It seems not?
    Thanks for the reply.
  4. drphibes
    drphibes
    Oct 23, 2002
    1,116
    48
    +33
    I think you are describing the "softmod".
    Do a search at http://www.xbox-scene.com/ and im sure there will be a tutorial on how this is done.
    Drphibes
