Xbox Chipping - which?
Discussion in 'Xbox Forums' started by Spookyville, Oct 24, 2004.
  1. Spookyville
    Spookyville
    Jul 20, 2000
    262
    Bradford, UK
    +8
    Have just recently got an Xbox and am looking to chip it shortly. have done some searching in relation to the mods available - what in peoples opinions is the one to go for - a Xenium or the X-Ecutor 3 ?
    Thanks..
  2. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    The Wheldon Road end!
    +8,370
    Just gone for an Xecuter 2.6 myself - couldn't see the point of getting an Xecuter 3, especially as it's around an extra £15.
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    went for an xecutor 3 because it stops live access when enabled on the newer 1.6 xbox's which none of the others did.
  4. CAS FAN
    CAS FAN
    Nov 24, 2003
    35,343
    2
    167
    +8,370
    True, I guess that stops those moments where you forget to turn off the chip :eek:
  5. Spookyville
    Spookyville
    Jul 20, 2000
    262
    Bradford, UK
    +8
    thanks for replies. looks like its an x-ecutor 3 then :)
  6. Del Boy Smiffy
    Del Boy Smiffy
    May 4, 2004
    6,499
    Yeovil
    +416
    Spooky, where you getting it done and how much, im looking around for prices as im getting mine chipped.
  7. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Apparently Xenium is the way to go these days. I have an Executor 2 in mine which has worked perfectly for over a year. There are no issues with live unless you are an idiot and go into live with the chip on, I can never understand people getting worried about this :rolleyes:
    Going rate is around £40 - £50 for someone to install it for you inc chip.
  8. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Got my Executor 3 last night, opened up the xbox spent about an hour removing the solder from the LPC ports, since i ahve a first gen box it was filled with solder, was that was all out, put the pin header in, soldered that in place, put the chip in, connected up the wires and powered up.
    Worked first time, flashed the BIOS over the network, backed up the folders it said to, once it was working, got a 80Gb drive i had lying about put that in, it took seconds to configure the drive, copied the drives back over, installed a new dash, few apps :)
    Also you dont have to use a Video Switch disc since the video settings can all be done in the Config Live system.
    Well pleased with it
    Nikumba
  9. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Mate did mine for me last night took him about an hour or so to do the Xecutor3 chip on a 1.6 board. He's going to stick XBMC on tonight then I should be off to play games in hidef !
  10. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Very pleased with my Xenium, lots of good stuff and works very well.
    A slight issue with auto video switching through the advanced scart.
    You actually get a blank screen and have to press the green button three times to start it.
    Other than that superb.
    Very glad I opted for a 120GB HDD as well now.
  11. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    HD upgrade is essential and 120 gig is a good balance between cost and capacity. Its what I have in mine. However If I was doing mine now I would probably pay the extra £20 or so and go for a 160 gig.
  12. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    When I listed all my must buy games I got to a list of 20 or so.
    Even assuming 5B each I'm still safe.
    You're right though. For £20 you can play another 10 or so games from the HDD.
    Playing from the HDD is so much quicker it's unreal.
  13. Stellavision
    Stellavision
    Apr 7, 2003
    2,410
    Southsea, UK
    +105
    I've got a SmartXX. Very good chip and there is no need for external switches to disable it to go live. Simply boot into MS original bios from the bios/dash selection menu.
    For more info have a look at www.smartxx.com
  14. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    529
    North Cotswolds
    +3
    I've put the Xenium ICE on my xmas list. I like the idea of no dip switches.
  15. drphibes
    drphibes
    Oct 23, 2002
    1,141
    48
    +33
    I have also got a Xbox with a SmartXX chip.
    Does everything I want and I got it from premodded , Ben was very helpfull and I would recommend him.
    Drphibes
