Xbox and USA games
Discussion in 'Xbox Forums' started by oaklandraiders, Dec 15, 2002.
  1. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,244
    Surrey
    +48
    YO
    Not that I've got one yet, but if I buy any USA games will they play in UK xbox or does regional coding stop it.
    ANy way around it aprt from having it chipped ?
    John
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    You need to chip it or convert it to a US machine by flashing a US BIOS. If you opt for the latter though, your UK machine effectively becomes a US machine and won't play UK games. There may be issues with chipping and Xbox Live so read up on this first.
  3. dmg
    dmg
    if you get it chipped then you'll be able to play all region games no problem, see www.xbox-scene.com for all the info you'll need.
    If your planning on using xbox live however once you have chipped machine you wont be able to connect for now.
  4. NeoBlade
    NeoBlade
    You will be able to connect to XBL with a modded Xbox.... All you have to do is to turn off the mod chip itself. The X-Ecuter II does this via the eject button but other chips can be turned off via a hardware switch.
    You can still go on XBL with an enabled modded Xbox however but things get a little more complicated. Again, just search around and you will find the answer.
