xbox and surround sound
Discussion in 'Xbox Forums' started by rb5201, May 11, 2005.
  1. rb5201
    rb5201
    Apr 20, 2005
    2,112
    63
    essex
    +214
    Sorry if this has been asked and answered a hundred times but I am unsure of which cables to connect my xbox to my amp to get the best picture and surround sound? Scart/RGB/comp/optical cable?? I have a uk xbox, not modded or chipped in any way. My head is spinning as I do not want to buy the wrong one, can I just pop into my local Game store and get what I need??
    Please help, thanks :)
  2. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    Get the MS Advanced AV Pack with the Optical out on the little break out box, you will need to buy a optical cable mind.
  3. dvdsubtitles
    dvdsubtitles
    I've got a Joytech AV pack which includes optical out, it only cost me £8.99 and sounds fabulous. Was looking for MS version but couldn't find one anywhere.
    Can't compare with MS version but I have heard that the MS accessories are generally the best.
    Cheers,
    Mat
  4. rb5201
    rb5201
    Apr 20, 2005
    2,112
    63
    essex
    +214
    Where did you get the joytech pack from? The ones ive seen have 5 plugs to go in the amp, is this the one I need?
  5. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    I use the MS official scart lead which has a box half way along the lead with a digital connection on it. Use a digital optical lead from the break out box to your amp and away you go. Picture via scart is fine, but I have a standard UK box so can't use the component leads on my 36" JVC tv.
  6. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    This website sells them, not necessarily the cheapest but in the UK.
    Matt
  7. dvdsubtitles
    dvdsubtitles
    I saw them in a lot of places - I think it was MVC in Hounslow where I eventually bought mine - some places were overpriced others out of stick.
    It has an optical out and comes with an optical cable - so only one connection to amp needed (to digital optical in).
    Cheers,
    Mat
  8. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    I would get one of these if your happy with scart, if your not modding your box in anyway component is not really worth it. I used to use one and it was fine.
