Xbox and region coding?
Discussion in 'Xbox Forums' started by mandlebrot, Dec 26, 2002.
  1. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Is there any software/boot disc or swap trick that can be used to play R1 DVD's on an R2 Xbox?
    I know if I chip it that will do it but don't want to chip it just yet. I also know that I could flash the BIOS to make it an R1 but I want to keep it R2 with switching to R1 on occasion or make it multi region.
    Any ideas?
  2. JSW
    JSW
    Feb 21, 2002
    4,268
    Staffs
    +333
    I think theres a disc called region x you can buy for 19.99 that will do it.
  3. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Thank JSW but I don't think its out yet. Any other fixes about?
