Xbox and panansonic ae-100 progressive scan
Discussion in 'Projectors, Screens & Video Processors' started by jumpt_upmunky, Jan 5, 2003.
  1. jumpt_upmunky
    jumpt_upmunky
    Jan 5, 2003
    186
    28
    Hove
    +29
    Just bought the panasonic and i have to say it's FANTASTIC but i've found one flaw, i've spent the afternoon searching forums etc trying to find anyone with a similiar problem but to no avail!
    The problem is I connect the xbox to the Panasonic using Gamester Component Cables, it's a PAL xbox but it's set to ntsc using the VideoMode switch disc so it's outputting NTSC.
    I get progressive output to the panasonic but the image is ghosting it's not too bad on 525p but on 750p (tonyhawk 4) and HDTV60 (Dragons Lair 3D) it's really noticable
    So it's either the projector (which I have no real way of testing because I don't have anything else that outputs progressive scan)
    or it's the Gamester Cable which I suspect it might be. but I cant find anywhere that sells the Microsoft hi-def kit or the Monster Component leads in the Uk.
    or it's the fact it's a UK xbox at heart even though it's outputting NTSC.
    So if anyone has any ideas let me know!
