xbox and high def pack
Discussion in 'Xbox Forums' started by slingshot, Oct 12, 2004.
  1. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Couldn't find a straight answer when searching, I've just bought an XBox and will the high def component cable work OK (without hi-def I know) without getting the xbox chipped.
    I will eventually get it chipped but not at the moment so I'd still like a component connection.
    Slingshot
  2. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,956
    2
    Manchester
    +4,470
    Yes it will work. Mine does.
  3. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,109
    38
    +6
    You'll get a componant signal, but not Progressive Scan, untill you get your xbox chipped.
    fluffyyoda @ hotmail.com He's done 100's of xboxes before, send him an email.
  4. MarTTy
    MarTTy
    Jun 10, 2002
    34
    I have the official hi-def kit and before I got my xbox chipped the colours were all washed-out even when using component out...when you get it chipped the difference is amazing, the colours and the general picture are more vibrant. I used to have the lights turned off to play games on my AE100, but now i'm chipped I can leave the lights on! :blush:
  5. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Can I ask a dumb question. If I had my xbox modded either via a chip or a softmod and then had the a set of component video cables from Monster Cables, would they give me hi def or do I need to get a Micrsoft Hi-Def kit?
  6. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    My mates being doing them, but he's got a bit of a backlog and Mines a new Xbox which aparantly is a bit more difficult.
  7. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,109
    38
    +6
    You still need a high defintion pack.
    www.playasia.com > Xbox > Cables > Controllers
    If you want a reliable guy to do it for you, then that email address is the way forward.
  8. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    I still dont get it. Why do I need the Microsoft Hi-Def kit? What does this cable do that my MonsterCable GameLink™ 400 X wont do?
    Looking at the manual for the MS cable it provides a 3 cable conponent Y, Pr, PB signal which is just the same as the Monster Cable.
    I understand that I will not get HiDef out from the Xbox unless it's a US box or one that has a modchip or soft mod.
  9. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,109
    38
    +6
    I wasn't aware Monster did componant leads for high definition. Can you show us a few links? With price etc?
    Does it have optical out for 5.1 sound too?
  10. windfall
    windfall
    Oct 19, 2003
    2,422
    48
    LFC Kop End
    +65
    Hi Chaps
    toward the bottom of this page you will see the monster cables.
    http://www.x10.com/home/offer.cgi?!DFEED,../bizratedf2.htm?>44080
    Tone
  11. Scotty Boy
    Scotty Boy
    Nov 11, 2003
    1,109
    38
    +6
    Nothing there for me boss.
  12. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    monster do make them i know that.
    I know that most people who have them say they are better than the MS pack but to be honest it makes so little difference I think it is their imagination.
    Chris
  13. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    If I use a HI-DEF cable from M/S will I get 5.1 Surround sound ,or will it just be the picture that improves?
  14. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    Here is the link, http://www.monstercable.com/monstergame/xbox
    I currently use the s-video version for both the PS/2 and Xbox and these are very good quality cables. I had them shipped via a family member in the US, they cost about $45 each.
  15. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    the moster ones do cost a bit more but they are superb.
    You will normally get 5.1 surround sound if you get a high definition pack. So the sound is much much improved - however you need an amp/set of speakers which can handle optical in.
  16. pemberto
    pemberto
    Oct 14, 2003
    502
    28
    Huntingdon
    +32
    But can I use the Monster Cable to get HiDef from a modded xbox?
  17. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    Of course. Almost any cable that outputs component can be used for high def, its just a question of the quality you want from the cable.
  18. jimcarney
    jimcarney
    Feb 19, 2001
    641
    DOWNPATRICK CO DOWN
    +3
    By M/S I meant Microsoft sorry if I confused anyone!!.......Jim
  19. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
  20. John
    John
    Dec 13, 2002
    11,444
    +3,076
    The first one is the official MS pack , Component out , stereo out and optical out for DD. Comes with seperate component cable cable to go from it to TV input . Appart from an opt cable and soft/chip mod , etc .Thats all you need.
    You can substitute the Component Cable for a better/longer one if required :smashin:
  21. LiquidTV
    LiquidTV
    Sep 24, 2004
    169
    Cornwall
  22. thebigkung
    thebigkung
    I don't know if this will help but here is what I get using the Hi def kit on my Plasma which is Hidef compatible.
    The the HiDef pack connected to the xbox and xbox set to Pal.
    Option to run Pal 50 (xbox setting 'no' pal 60) or Pal 60.
    Running Pal 50 and Pal game Display sets to 625i (575i)
    Running Pal 60 and Pal game Display sets to 525i (480i)
    Running Pal 50 and NTSC game Display sets to 625i (575i)
    Running Pal 50 and NTSC game Display sets to 525i (480i)
    The the HiDef pack connected to the xbox and xbox set to NTSC with
    480p, 720p and 1080i options set to Yes
    Running Pal game Display sets to 525p (480p)
    Running NTSC game Display sets to 525p (480p)
    Running NTSC game that is 720p compatible Display sets to 750p (720p)
    Running NTSC game that is 1080i compatible Display sets to 1125i (1080i)
    Hi res games used. Soul Calibur II - Fantastic quality graphics at 720p, but it does not run in widescreen.
    Dragons Lair 3D - Crap game - Super Hi res 1080i
    True Crimes - Streets of LA - Fantastic graphics in 720p but driving seems slower.
    Syberia - Again superb graphics at 720p but screen is shrunk. Cut sceens are full screen but lower res.
    Pal games used. Outrun2, Dance uk.
    All pictures when run in NTSC mode were noticeably better than when the xbox was set to Pal.
    Have fun
    thebigkung
