zedzed
Established Member
Hi all,
I'm (hopefully!) going to be buying a Panasonic TH-42PW6B soon - and I'm looking to standardise on component YUV input to it.
I'm hoping to send all my connections (telewest/DVD/xbox) to a YUV switch, and then run a YUV to VGA cable to the plasma.
I know that for my telewest box I'll need an RGB2YUV convertor in place - but I was wondering - can I just connect my (un-modded PAL) xbox to the YUV switcher using an Advanced AV cable (using YUV, obviously!) and get this to work? The xbox will be outputing in 480i - but will this matter?
Cheers,
ZedZed
Cheers,
ZedZed
