Xbox and 720P
Discussion in 'Xbox Forums' started by johntaylormfc, Jul 5, 2005.
  1. johntaylormfc
    johntaylormfc
    Feb 19, 2005
    89
    +4
    I am about to get a new LCD TV and am looking to use my Xbox to display games and films at 720P.
    The problem I have is that when I switch of my ModChip I get a screen saying Service Required. Also fomr within the Evolution dashboard when I go to try to go to settings it returns me to the Evo menu. I assume it is the same problem.
    What I am looking for is another way to set the resolution to HiDef.
    I have used the Enigma Switcher to set my Xbox to NTSC, which I believe should give me that option when I go into settings, but cannnot get in to that screen.
    Are there any programs tahat I can use to change the resolution. I have tried XBMC but cannot find anything.
    The xbox works fine as it is throught EVox
    Any suggestions
    John
  2. The Departed
    The Departed
    Jul 6, 2005
    2,853
    137
    Fife
    +1,224
    Have you fitted a new hard drive in your Xbox at some point?
    If so, I think the problem is that the new hdd is still 'unlocked'. I was receiving a similar message when I upgraded my hdd (only when the mod was disabled) but after locking the drive it worked fine.
    Hope this helps :)
  3. Matt C
    Matt C
    My xbox had the same problem.
    I just reinstalled the slayer evo X program (formatting the h/d) and it worked. My hard drive was unlocked.
