xbox 360 + WLT66 - Should I buy VGA for SD DVD playback
vaseston
After extensive searching I still can not make up my mind what to do.
I have a 360 connected to my tosh WLT66 via component.
I have read that the 360s recent update allows DVD upscaling but only through VGA connection.
If I get a VGA cable I would be able to set the resolution to the native resolution and therefore get 1:1 mapping.
Can anyone tell me from experience whether there would be a noticeably better DVD playback using VGA than component?
(I do not have the HD-DVD drive)
Thanks in advance for any help
sinizterguy
VGA will allow to set a wider variety of resolutions and will probably give the best results.
I cant comment on upscaling over component or VGA as I currently dont have an XBox setup to test.
vaseston
Thanks for the reply Sinzterguy.
I just had a go with a vga cable I borrowed off someone at work and to be honest I could not really tell the difference with games and DVDs.
I had a play with different resolutions but I still could not get a SD DVD picture that I was 100% happy with. Maybe I will have to buy the HD-DVD..... :)
MikeKay1976
The WLT66 is a great set, BUT it cannot do 1:1 pixel mapping.
you are better off with component with this tv.
