Xbox 360 Wireless Headset advice
Ewan154
Getting ready to buy a Xbox 360 Wireless Headset. Just wondering if they are any good? Some people have written reviews saying that the voice sounds terrible and they break easy.
Any advice? suggestion?
t1m103
i bought one the day they came out and never had any issues with it,the only thing i didnt like was it wasnt chargable via a usb lead,it had its own plug to charge but i believe they are now equiped with a usb charging lead.
Ewan154
Thanks for the reply.
Hillskill
Moderator/Games Reviewer
They are top draw. In terms of comfort compared to the wired headset they are a head and shoulders above. The only issue you may have is if you use Wi Fi, i often forget to switch the wireless off on my laptop and that causes a bit of mic interference. My connection to the xbox is wired so its only the laptop that could ever cause problems.
Sniper Ash6
i use wireless on my computer and my 360 and many other devices and love my wireless headset, people sound so much clearer as well as it being light
it is very good if you have the money, yes it now has the USB charging lead the only downside is once the battery is dead you have to get it replaced (i dont know if M$ will do it as warranty on accessories) as well as remember to turn it off as when the console turns off the headset doesnt
Breminator
Out of the people that I know have them their voices seem very quiet compared to when they are using the wired headsets.
As far as durability is concerned I've not heard one gripe in that respect.
Sniper Ash6
my friends have never complained of me sounding quieter, the only way they know im using it is they say its clearer and tends to pick up less background noise
sunny937
Hi ive had connection problems with my xbox360 adaptar, for some unknown reason the red light just stays on and it says not connected when i test the connection. I have tried retyping in my ip address and other settings of that nature and restoring factory defaults and nothing seems to work, im really starting to get annoyed and i just have no idea if anybody could help it would be much appreciated thank you!
Breminator
Well I guess it's different on a case by case.
Personally to use 2 examples, one xbox live buddy is very loud and it is seen as a blessing that he voice is a little quieter (in my experience) with the wireless headset.
Another person is quieter and we can barely hear the guy especially while in a game of halo 3.
Sniper Ash6
the wired headsets can be fairly quiet as well as in the earphone
but for the people that sound quiet its just they dont talk loud enough etc so the noise cancelling includes their voice
Delvey
there very good, not problems with mine
another problem is if that you are charging it and using it, then everyone tes background noise (humming)
Mattk84
1 thing of note is the age of your controllers. the headset will only work with newer controllers. i have one older and one newer controller so can only play on live using one of them.
Sniper Ash6
it shouldnt make a difference the age of the controllers it should work no matter what
how do you charge it and use it its quite a short cable and would be annoying
Sniper Ash6
for most people that is not a problem as generally people have newer consoles and/or newer controllers that have been bought so i expect few with have problems on that side of things
Mattk84
i'm sure you are right. i am amazed how little this was discussed on t'internet. i only knew about it after reading the headset review on play.com.
iand68
i was thinking about getting a wireless headset, but went for the wired 1 instead. From the reviews I read, the wireless headset tends to be quieter, but better quality sound.
Does anyone know where I can get a Plantronics Gamecom headset at all? Thought I may try them and see how they perform.
Sniper Ash6
i believe the earpiece of the wireless headset can go louder than the wired one
Tetlee
This has been my experience, strangely I did find it quiet when I first starting using it and did think it was quiter than the wired one, but it almost seems as though it needed breaking in as it's perfectly loud now and very clear, wouldn't want to go back to the wired headset.
Perfect solution if you have a chatpad as the wired headset that comes with that is terrible IMO(muffly).
Sniper Ash6
the wireless headset is brilliant and love using it then am really unhappy when have to use the wired one
but try to use wired as few times as possible
