XBOX 360 viewing errors
Discussion in 'Xbox Forums' started by cojae, Dec 19, 2006.
  1. cojae
    cojae
    Nov 30, 2006
    77
    I have recently bought a premium xbox 360. When I'm playing on the console it seems to work fine, however most of the time I have to switch it on 2/3 times to be displayed on the tv. Does this mean my xbox 360 is faulty or just a bug with microsoft?
  2. Praxidike
    Praxidike
    Aug 8, 2006
    1,992
    Doncaster
    +117
    A similar thing happens with my TV I think - if I select the component input before I turn the 360 on, it usually doesn't work.... but if I turn the 360 on first, then select component on the TV, it works every time.
    Hopefully it's just an easy solution like that.
  3. cojae
    cojae
    Nov 30, 2006
    77
    It has the same problem when i switch to the component channel after turning on the console. Also one time the display showed a checkered screen with the game just visible behind it.
  4. RGP
    RGP
    Oct 26, 2005
    1,488
    St.Albans, Herts
    +32
    Some tv's like mine have auto switching to component, handy feature.
  5. Praxidike
    Praxidike
    Aug 8, 2006
    1,992
    Doncaster
    +117
    Ah, I've heard of the checkered pattern on people's xboxes that need replacing as they've gone wrong.... might be the case here, hopefully not though!
