Xbox 360 & Toshiba 27wl56P
Discussion in 'LCD & LED LCD TVs Forum' started by JayHarkin, Aug 29, 2005.
Tags:
  1. JayHarkin
    JayHarkin
    Hi Guys
    I have just pulled the trigger on the Toshiba 27WL56P. However I want to connect my Xbox and Xbox 360 (in the future) to it via component how and what do I need to do this. Also will the VGA to VGA Xbox 360 cable give me a Hi Def picture on the Toshiba. I am very confused any information much appreciated.
    Regards Jason
  2. kRAyZZed
    kRAyZZed
    Aug 26, 2005
    48
    Well the vga cable is ideally only really for connecting it to a PC monitor, as it outputs 1024x768 for 4:3 PC monitors
    the component cables that come with the machine in all regions allow 720i, 720p and 1080i
    and 720p is 1280x720, according to the specs of the toshiba it goes upto 1280x768, so this would probably be your best option, granted will most likely scaled down 1080i inputs too but will probably look better with the progressive scan, correct me if im wrong guys?
    so simply put you shouldnt need to purchase anything to play your xbox360 in HD as long as you have component inputs on your tv, if it does not, then it will have to be the VGA route, although that would be a 1024x768 image, either stretched or windowed.
    Sadly the 360 isnt comming with any 'digital' outputs (HDMI..)
  3. JayHarkin
    JayHarkin
    Hi Guys
    Would a VGA to Component Breakout Cable (5 Wire Female) do the trick for Hi-Def Pictures on the Toshiba via the Xbox & the Xbox 360. Also where would you buy such a cable? Also where do you buy VGA Component Adapters.
    Regards Jason
  4. JayHarkin
    JayHarkin
  5. markshark
    markshark
    Jan 6, 2005
    Pontypridd
    Hi Jay, I think the Hidef cable in the 'premium' Xbox360 pack has the standard 3 leads for HD component, 2 video cables for SD connections (using a Scart adapter) and also uses an optical output for 5.1 surround sound?
  6. JayHarkin
    JayHarkin
    Would I be able to recieve Hi Def through vga on the Tosh if I used a component to Vga adapter, like the one in the previous link?
    Regards
  7. JayHarkin
    JayHarkin
  8. MADMAND
    MADMAND
    Aug 4, 2005
    356
    +8
    No that will not work with HIGH DEF you will lose picture quality using component on that switch box.
    If you buy an HIGH DEF compatible amp like the yamaha rxv450 you will be able to use the supplied component cable for HIGH DEF.
    (With the yuv to vga cable)
  9. maxlifo
    maxlifo
    Feb 11, 2004
    108
    the VGA cable does 720p etc. Check out the official 360 site mate ;)
  10. kRAyZZed
    kRAyZZed
    Aug 26, 2005
    48
    no it says it accepts signals of that, however you will find via the vga cable it will scale the image to the 1024x768 (4:3) resolution - Check out the xbox.com press release by J Allard about this.
  11. maxlifo
    maxlifo
    Feb 11, 2004
    108
    check out this thread:
    http://forums.xbox-scene.com/index.php?showtopic=436338
    These are the details from the official MS press release.
    Clearly marked and color coded audio and video connectors make it easy to know where to plug each connector in.
    Unlock true Xbox 360 Hi-Definition gaming with video output settings of 480p, 720p, or 1080i.
    DV-15S Standard VGA Connector.
    Gold plated stereo audio contacts for maximum clarity and signal transfer.
    Mylar foil and copper braid shielding protect against radio frequency and electromagnetic interference.
    8 feet long shielded cable.
    Digital Optical Audio Output—optical cable sold separately.
    Stereo Audio Output.
