XBOX 360 to NAS drive
M
mjdennison
I have an XBox 360 and I also have a LinkStation NAS drive on my network, I want to put my music onto the NAS drive but the XBox 360 cannot see it? Is there anything that can be done, if not what type of NAS do I need as I know that some people on forums have said that it can be done?:rolleyes:
Yorkshirelion
Thats right if you have just a standalone NAS drive your 360 wont see it.
I have a Maxtor Shared Storage II 1tb edition and that has Twonkymedia installed on the device, this way the 360 recognises it and will play all my music and videos. I did this by putting a special firmware on my device.
Check on twonkymedias website to see if your nas drive is compatible. :smashin:
I have just seen the above post also, even if you add the folders the 360 wont see them.
M
mjdennison
Brill put Twonkymedia on the drive (at long last, took a bit of brain searching but got it in the end) and all if now working fine.
Thanks for your help:thumbsup:
dsmuk
I have just been trying to install this on my Maxtor Shared Drive plus but I keep getting an error message saying
Open a telnet connection failed, please check IP address of MSS
The address is correct, the anti virus and firewall is turned off.
Anybody else had this problem?
EDIT: Sorted it now, not sure what was going wrong but a restart of the computer, router and MSS seemed to do the trick!
djcla
i have same problem with my network drive if you use an app like tversity will it see the nas then?
dsmuk
Should I be able to watch divx videos like I can with transcode360 using this TwonkyVision or not?
djcla
I have got this to work using Ubuntu (Linux) and Twonkymedia , not sure if it would work in XP with TwonkyMedia or not.. (seeing a NAS drive that is)
davidm
I have a Linkstation on my network and using Tversity I can watch video and listen to music from the NAS box through the Xbox 360.
djcla
i don't think it will work with twonkyvision i maybe wrong though as i have only tried with Linux version and have not seen a transcoding opion
