XBOX 360 Sounds Drops When Streaming Music
Discussion in 'Xbox Forums' started by Red-VIII, Jan 21, 2008.
  1. Red-VIII
    Red-VIII
    I have a problem when streaming music from my Windows Vista Laptop to my XBOX 360.
    When listening to music the 360 will normally about two thirds into the track stop outputting the sound until it moves onto the next track, it will then do the same on the next track and so on and so on.
    I find if i reset my laptop and then the 360 it normally sorts the problem out and i get uninterupted music.
    I though the problem could be that the laptop was loosing connection with the router but when the problem occures i can still connect / browse the internet without problem.
    Any help would be most appreciated.
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Are you connected wirelessly or wired?
    If wireless what speeds are you getting?
  3. Red-VIII
    Red-VIII
    My Laptop is connected wirelessley via belkin router/modem, the 360 is wired directly into the router. My laptop always has a full strength signal so i would say it was it must be connecting at a full 50mbps.
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    Well if you are getting 50Mb you should not have a problem, but for the sake of testing plug your laptop into the router as well and see if you get the same problem.
