Xbox 360 Slim wont read games anymore
Discussion in 'Xbox Forums' started by joeac, Mar 10, 2013.
  1. joeac
    joeac
    Mar 23, 2008
    1,780
    48
    +96
    Hi guys
    My xbox 360 slim wont read disks anymore, I put the disc in and it says 'Disc is unreadable. Please clean with soft cloth' I have tried it with 5 games and it all always says the same thing. If its not the DVD's motherboard I would like to swap it out for a new dvd drive.
    Can someone explain to me the whole process I would need to do to get the DVD drive to function again. In case the issue is the PCB on the old DVD drive, what are my options? as i understand the old PCB is required to be placed onto the new drive
    Thanks in advance
  2. joeac
    joeac
    Mar 23, 2008
    1,780
    48
    +96
    More research suggests that if the PCB is faulty then I need to put the old key onto the new drive? Could anyone give me a step by step on how to do this please?
    The exact problem here is that as soon as a game goes to load it says 'disc is unreadable, please clean disc' is this more likely to be a problem with one of the drives components such as the laser or the DVDs motherboard? If it were not to be the motherboard I could easily swap it over to the new drive but if I do discover it is the motherboard what could I do about it?
  3. joeac
    joeac
    Mar 23, 2008
    1,780
    48
    +96
    Can anyone please help?
  4. Harry Clayworth
    Harry Clayworth
    Feb 25, 2013
    24
    3
    You could try a lens cleaning disc as it could just be the laser is dirty (it probs wont be the case but worth a try at least)
  5. sajm27
    sajm27
    Jan 17, 2009
    12
    If cleaning the discs and the lens does not work, it could well be that you need a new laser in your DVD drive. I had the same problem and fitted a new laser which fixed it.
  6. bernado
    bernado
    Oct 24, 2009
    1,579
    +462
    An unlikely fix of the same problem for me was to clear the cache. Worth a try in case you haven't already started other hardware related fixes
