lersince1991
Established Member
So I need to connect my 360 to my monitor as I dont have a tv or space for one.
At the moment I have an Acer p223w which has 1x dvi-d and 1x vga inputs. I use the VGA frequently for my macbook pro as an external monitor (why I bought it). So this leaves the DVI-d port free. I also need to plug the xbox into my hi-fi separates system. (Amp with RCA connections -> B&W 685 speakers).
So I have a few options and was wondering if you lot had any preferences.
I dont want to be swapping cables round, I dont think I'm the the market any time soon to upgrade my amp to one with optical or upgrade my monitor to one with hdmi.
I currently own the 250gb 360 and have some cables from my old xbox including an official vga cable. The xbox will be in a cabinet and need a 3m video cable at least, but next to the amp so sound cables need to be short.
1. Xbox Video - HDMI - DVI-D 3m £5.49
Xbox Sound - official 360 sound adapter using RCA - RCA to RCA cable - amp £6
2. video - hdmi to hdmi, + hdmi to dvi-d adapter. this gives me a hdmi cable that I can actually use when I upgrade.
sound - same as above
3. use the vga cable I have, extend the vga to 3m to reach my screen, but then use a vga switch to switch between laptop input and xbox input to the monitor.
4. trim the standard def plug that comes with the new xbox to plug in my hdmi to dvi lead and use the modified cable for sound.
p.s. Is the new version standard def cable thats included still work perfectly if I trim the plug down to fit hdmi and the xbox av connection in? I saw the mod that used the old xbox cable.
more notes -
I'm thinking about getting a freeview hd box and connecting it up with a HDMI - DVI-d lead. If I get one I will have to keep swapping cables which annoys me -_-
I want a solution that works for a decent price, minimal fuss and good quality.
Is there any difference in quality between these?
I dont really think there will be?
Thanks for your input.
Luke
more notes -
Luke
