Xbox 360 Play & Charge Kit
Art Vandalaay
I just used the Xbox 360 Play & Charge Kit for the first time and I cant disconnect it from my controller, it just feels that it will break every time I try to pull it out, is there something I should be doing to make it disconncet or should it it just pull out easily
DarkEntity
Just give it a firm but controlled tug and it will come out.
K
Kycleung
Yeh I found this the first time I charged my controller. Just give it a firm tug, then pull from under the connector.
m40wen
:eek: :eek: :eek:
Daddy k
iv hear a rumour that the play n charge kit chrges the controller when its on standby (switched off but plugged into power supply still)
however mine doesnt ansd only charges when console is fully on
is this normal??
chuwright
Established Member
is this normal??
Mine charges in standby, but first connect the controller while the console is on. I didn't realise, closed the cabinet doors, woke up to find my AV cab had become an oven!
Tejstar
I have noticed that with my rechargeable battery, I get a faint green light on the bottom right quadrant of the controller when it's not in use. Has anyone else had that?
K
Kycleung
Yep I can see this too, only in the dark though. The 2nd and 3rd quadrants are dimly light. Once I take out the rechargeable batteries, the lights completely go out. :confused:
peahead
You can charge the pad in standby mode and when its charged the 360 will turn itself off.
wormvortex
you can charge the 360 wireless controller using the ipod lead remember reading it somewhere. Obviously not planned but apparently works
Daddy k
can someone describe standby?
do u mean on the menu screens?
Steve-L
Hold down the xbox guide button until a menu appears on the right, then select shutdown/turn off console at the top (from memory, could be worded differently). It will charge your battery and then turn itself off :smashin:
Daddy k
so normal turn off then.
mmm ill check if my play n charge charges when in this state. im sure it didnt before
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
