Xbox 360 Play & Charge Kit - £7.76
Discussion in 'Shopping, Deals, Discounts & Bargains' started by Gliese 581c, Jan 5, 2007.
  1. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    Get it from here
    http://us.codejunkies.com/shop/product.asp?c=GB&cr=USD&cs=$&r=1&l=1&ProdID=320
    Dont forget to change the currency from £ to $, it will change it to $14.99 and its still sent from UK warehouse.
    According to xe.com, $14.99 is roughly £7.76
    :thumbsup:
  2. Parmenion
    Parmenion
    Feb 6, 2002
    1,307
    Out there
    +74
    link doesn't work for me
    regards
    Parmenion
  3. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    This one work ?
  4. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    wwooops, just noticed its the same...
    try following the sections through by going to the main page, xbox 360 section and searching for the plug and play item.
  5. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    I meant to post this myself,I received mine this morning for the reasonable sum of £7.59.
  6. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,852
    7
    2
    167
    Birmingham, UK
    +10,807
    Moved to the gaming bargain forum.
  7. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    Keighley, West Yorks
    +142
  8. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    Doh ! Forgot about that one :( Ta for moving.
  9. dlpfan
    dlpfan
    Probably you should mention it is not an official one, but is made by datel.
  10. eatstatic
    eatstatic
    Oct 22, 2002
    1,138
    Centre of the Universe
    +45
    Anyone know how long the cable/wire that comes with this is?
    Couldn't see it on spec.
    Thanks.
    Eatstatic
  11. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    A bettery charger is a battery charger. Nothing worth mentioning in my opinion.
  12. dlpfan
    dlpfan
    In case there is any doubt over the differences: Microsoft US does not share the opinion (see E) above which is significant for those who are still under warranty and wish to protect their rights should anything go wrong as a consequence of this 3rd party product (with no XBOX compatible logo I can see). Therefore, I felt responsible to draw the attention of viewers directly to the fact that this is not a Microsoft product because when faced with a bargain it is easy to miss this detail. I still thank you for posting the bargain but I just didn't want someone to purchase this unknowingly, and if I did not reply to your response above, someone may be under the unsubstantiated belief that the products are "equivalent".
    E. EXCLUSIONS FROM LIMITED WARRANTY
    This Limited Warranty shall not apply and Microsoft has no liability under this Limited Warranty if the Xbox Product:
    * is used with products not sold or licensed by Microsoft (including, but not limited to, non-licensed games and game enhancement devices, adaptors and power supply sources) or which are otherwise incompatible;
    whereby the term "Xbox Product" means, depending on the context above, either: (i) the Microsoft Xbox 360™ Video Game System console including (when considered as a whole) the Microsoft software stored on the separate Xbox 360 hard disk and/or embedded in microprocessors within the Xbox 360 console ("Console"), or (ii) Microsoft branded Xbox 360-compatible hardware accessories manufactured by or for Microsoft, whether included with the Console or purchased separately ("Accessories").
  13. Gliese 581c
    Gliese 581c
    Feb 3, 2002
    8,863
    2
    On AVForums
    +586
    Microsoft love people like you. :laugh:
  14. madcyril
    madcyril
    May 30, 2004
    1,049
    Manchester
    +94
    The cable is 10 ft.
  15. ianburnip
    ianburnip
    Sep 11, 2006
    193
    like they're gonna know you didn't use the microsoft thing. i've used ps2 memory cards that cost £3 - when it broke, did sony know............Nope!
  16. eatstatic
    eatstatic
    Oct 22, 2002
    1,138
    +45
    Cheers for that.
    Eatstatic.
  17. SGR2005
    SGR2005
    Jan 27, 2005
    410
    28
    +60
    Good deal.
    Damn, and I ordered the Official Microsoft one for £8.99 the other week from CD-Wow and have been getting delayed stock notices ever since.
    Good job I don't need it urgently. And I can cope with paying an extra £1.23 for the official.
