Xbox 360 output in DTS?????
Discussion in 'Xbox Forums' started by robabsalom, Jan 5, 2007.
  1. robabsalom
    robabsalom
    Apr 25, 2006
    Hi can someone help me here.
    does the xbox dvd drive (not the hd one) out put in DTS audio. I have tried playing dvd with dts audio, but my av receiver just says its dolby 5.1?
  2. maverik1979
    maverik1979
    May 27, 2006
    84
    +5
    i think that because it outputs a digital stream it will output dts,
    however some amps dont autoswitch to dts they sometimes have to be told to switch
  3. swanny78
    swanny78
    Apr 19, 2005
    1,041
    48
    Matlock
    +66
    no it downsamples to DD. There is a patch coming shortly apprently to fix this.
  4. robabsalom
    robabsalom
    Apr 25, 2006
    i new that was a problem with the hd drive but wasn't sure about the standard dvd drive.
    cheers
  5. prettyvacant
    prettyvacant
    May 22, 2006
    363
    Wolverhampton
    +55
    Funny, my Denon AVR2106 recognised a DTS stream from my Pirates of the Carribean DVD and my Led Zep Live DVD.
    Sure that isn't just the HD DVD Drive? I read it downmixes all DD+ and DTS HD Tracks to vanilla DD 5.1? :confused:
  6. robabsalom
    robabsalom
    Apr 25, 2006
    so if thats the case why is my amp not recognising it?
    i've got the sony STRDA 1200ES anyone with this amp have the same problem?
  7. maverik1979
    maverik1979
    May 27, 2006
    84
    +5
    on my amp i had to set audio switching to auto so that when it detects a dts stream it autoswitches, but it wasnt this way by default
  8. prettyvacant
    prettyvacant
    May 22, 2006
    363
    Wolverhampton
    +55
    This is gonna sound cheeky but it's not meant to be :devil: ...
    Have you selected the DTS audio track? Some discs come equipped with both DD and DTS tracks (the fantastic Led Zep one for starters).
    I used to have a Sony STRDB930 a few years back which automatically picked up DTS tracks and switched. Can't imagine Sony would change that
  9. robabsalom
    robabsalom
    Apr 25, 2006
    yeah i selected the dts track on the dvd but not sure what to do on the amp to get it to realise!!
  10. maverik1979
    maverik1979
    May 27, 2006
    84
    +5
    go here and it explains how to set the amp to auto switch the input to correct decoder
    http://pdf.crse.com/manuals/4246802171.pdf
    i realise its not the exact same model as yours, but i imagine it will get you somewhere near
  11. swanny78
    swanny78
    Apr 19, 2005
    1,041
    48
    Matlock
    +66
    Come to think of it it is the HD DVD 'm talking about, i'll get in my box, sorry :D
  12. Mac User
    Mac User
    Sep 27, 2006
    4,551
    Norfolk
    +309
    Yeah i cant waiting for this patch, Does anybody know when it will become available ?
  13. swanny78
    swanny78
    Apr 19, 2005
    1,041
    48
    Matlock
    +66
    not heard anything yet, im guessing this will be one of the first places to get it.
  14. bigkingy
    bigkingy
    Jan 23, 2006
    1,101
    Forest of Dean,England.
    +183
    Strange problem, as when I change the sound to DTS on the DVD menu (If available of course..) my amp says DTS on the display and it plays perfectly!
  15. CAFCmatt
    CAFCmatt
    My 360 allows my Logitech to play back DTS. Plays fooking quality too
  16. uksmurf
    uksmurf
    Apr 8, 2006
    79
    Berkshire
    +13
    My Pioneer amp also picks up and plays a DTS soundtrack without a problem.
  17. Nanor
    Nanor
    Mar 14, 2006
    452
    Liverpool
    +56
    I've been having no problems with this either. Have tried Gladiator on DVD and it picked up the DTS stream when i used the internal drive and the external HD drive.
  18. sideysid
    sideysid
    Jan 2, 2005
    471
    +31
    I've got this amp and tested out a DTS and a DTS-ES 6.1 track last night.
    All worked fine without any problem. The 360 passes the DTS track through as DTS is not decoded within the xbox. This flags up correctly on the 1200ES which decodes it.
    What are your audio settings on the xbox dashboard? Also have had the latest update? Because I have seen on the Microsoft site that states the 360 does not support DTS, which must of been changed in an update.
    What I would like to enquire, is it possible to output bitsream for everything via the 360? Or does it pick and choose what it PCMs?
  19. swanny78
    swanny78
    Apr 19, 2005
    1,041
    48
    Matlock
    +66
    Are you guys gettin dts from the hd dvd drive? i aint !
  20. CaPo
    CaPo
    Dec 11, 2005
    938
    43
    Glasgow
    +186
    If I use a normal dvd then yeah, but with hd dvd's the dts track gets output as dolby digital. You will definately still be able to hear the difference with dts selected though.
  21. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    No it doesn't.
    It doees passthrough DTS without downsampling, your thinking of DD+\TrueHD\DTS equivalent of TrueHD, for the HD-DVD drive.
    YOUR XBOX 360 WILL OUTPUT DTS WHEN PLAYING A DTS TRACK
  22. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    You should be, I just watched "Hulk" last night, selected "DTS" track and the Xbox 360 is outputting the DTS track without any processing to DD.
    (Yes that is from the HD-DVD drive as well)
    ....A little confused now?
    You lot sure you've actually selected the DTS track on the DVD!!!!?:confused:
  23. robo989
    robo989
    Feb 14, 2004
    2,695
    68
    Carmarthen
    +70
    That doesn't actually make sense but I think your asking. Is it possible to get the 360 to always output a 2 chanlle PCM bit stream as opposed to using DD5.1 except for DTS DVDs which would be DTS....
    I'm pretty sure you can change it in the audio settings on the dashboard?
    Dolby Pro Logic II is still "PCM" mate ;)
  24. yaris123
    yaris123
    Mine wont output DTS at all is have a pioneer vsx-1016 and the dts track flickers between that dolby pro-logic and theres no sound.
