XBox 360 on WQHD 2560x1440 Display - 720p or 1080p?
Discussion in 'Xbox Forums' started by NightFox, Feb 13, 2014.
  1. NightFox
    NightFox
    Feb 22, 2005
    68
    Whitchurch, Shropshire
    I've always run my Xbox 360 on the 1080p setting connected to a 1080p monitor. However, I'm now upgrading my monitor to a WQHD 2560x1440 one, so the new monitor will need to upscale the XBox's output as it won't output anything higher than 1080p. However, 1080 to1440 scaling is by a rather awkward factor of 1.33, whereas I'm thinking if I set my Xbox to output 720p instead, the 720 to 1440 scaling factor is exactly 2 which I would imagine would make for a better image?
    Is my logic correct - by setting the Xbox output to a lower quality, should I in theory get a better picture (and hopefully less lag with the monitor's scaler having "easier" calculations to make)?
    Am I also right that in fact the Xbox 360 actually works natively at 720p and only achieves 1080p output by onboard scaling anyway?
  2. NightFox
    NightFox
    Feb 22, 2005
    68
    Hmmm, never thought of that, might give that a try if I can actually remember how/where the bits are to hook up a VGA cable to my Xbox! Thanks.
  3. NightFox
    NightFox
    Feb 22, 2005
    68
    Looks like the 360 only outputs a maximum of 1080p (maybe 1152) over VGA, and my monitor will only accept a max 2048x1152 over VGA anyway - so I'm back to choosing between 1080p or 720p over HDMI
