xbox 360 on laptop with vga port?
Discussion in 'Xbox Forums' started by supergeek, Sep 7, 2007.
  1. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  2. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    Nope. The VGA connector on the laptop is an output only.
  3. johnhy
    johnhy
    Dec 8, 2003
    1,811
    Glasgow
    +101
    might be possible to do it via a tv card input or a usb tv receiver dongle via s video
  4. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  5. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    The VGA cable certainly won't work as has already been mentioned the VGA connection is going to be output only. The second device I suspect won't work either but even if it did I would think the picture quality would be very poor. Essentially laptops are not designed in a way so that their displays can be used for external uses.
  6. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    hmm ok thanks for your help, but was just wondering if instead there was any way i could play it on a pc monitor?
  7. Kahled
    Kahled
    Dec 1, 2005
    1,799
    63
    +163
    If you have a standard PC monitor then it should take a VGA input, in which case you just need to buy the VGA cable for the 360 (with possible the need for a gender changer in between depending on the monitor connection). Used that connection myself for a short time before i missed the big screen (even at SD before I upgraded) too much.
  8. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    i have an oldish 20" monitor.. does it matter that its not lcd?
  9. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    As long as it has a VGA input, it should be fine.
  10. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    as a note, the official vga cable includes the gender changer also, most unnofficial ones don't.
  11. LBP.Nxe
    LBP.Nxe
    Apr 1, 2006
    586
    +255
    Even though the gender changer means it can physically be connected up, it doesn't mean it will work :)
  12. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    how do i know if it will or it wont?
  13. LBP.Nxe
    LBP.Nxe
    Apr 1, 2006
    586
    +255
    It won't. If it can, you would be reading about people using their old notebooks as secondary displays for their PCs, or (as you want) for the X360.
    But if you really really want to have it confirmed that it won't work then email Toshiba :)
  14. lostsoul
    lostsoul
    Feb 22, 2007
    271
    28
    +42
    why wont it work using a pc monitor?!?! certainly should if it has a vga input! i think you may have missed a few post there:D
  15. LBP.Nxe
    LBP.Nxe
    Apr 1, 2006
    586
    +255
    Oops :rotfl:
    Yes even an old CRT 20incher should support a reasonably high enough resolution even to take advantage of the resolutions available with the 360 :)
  16. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    PC monitors are HD and progressive scan by nature even the CRT ones. Any CRT with a VGA input and pretty much most old ones have one should be fine. Obviously if it is a 4:3 monitor then you will get black bars on the top and bottom but other then that it should be fine. How well it will look will depend on the maximum resolution of the monitor.
  17. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  18. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Can you make the image smaller or just link to it as it's way too big for these forums and is messing up the thread. Thanks.
  19. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  20. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
  21. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    The image isn't really very clear. What is the make and model number of your monitor or do you have a link to it's specs online. If it's a relatively old monitor then it should have a VGA input. Infact all CRT monitors should have VGA.
  22. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    its a 'hitachi cm2112me t' looks really old and i searched for it on google but cant find anything of any use.. says on the monitor that it was made in 1996 so that mite be why :s
    however.. it does have a vga cable coming out of it (that i would normally have to plug into my pc). The cable that comes out has the pins, and you stick that into the holes in the pc. So was thinking that maybe i could get a 'female to female vga converter' (http://cgi.ebay.co.uk/VGA-Female-to...ryZ41993QQssPageNameZWDVWQQrdZ1QQcmdZViewItem)
    I would plug the lead from the monitor into one side of the converter, giving me a free side on the other side of the converter, which has holes in it. I could then plug the lead from the xbox360 into the free hole?
    Dont know if this will work but its just my theory lol, although i found this page here n it seems to be saying similar things :)
    http://www.xploder.net/xbox-360/xploder-guides/4/Xploder-Xbox-360-VGA-Cable-Guide.htm
    (pics 3-5)
    thanks for all your help btw! :thumbsup:
  23. ZebraheadDude
    ZebraheadDude
    Feb 27, 2006
    1,273
    48
    +47
    Official lead comes with a gender changer mate, you're good to go :smashin:
  24. supergeek
    supergeek
    Sep 7, 2007
    1,224
    48
    everywhere
    +29
    aha, thanks :) :smashin::smashin:
