namastebuzz
Established Member
Hi All
I have an audio problem. Previous connected 360 to an AV Amp using AV HD Component Cable with the optical out for the sound. Worked fine. Switched it to my TV using HDMI for pic/sound. Worked fine.
Then, tried hooking it back up to Projector/Amp again with HD AV Component lead. Picture via Component is fine. No sound at all via optical out. Tested digi inputs on Amp with other sources - OK. Switched optical cable. No joy. Checked all the output audio settings on console. Switched to stereo output and used 2x RCA outputs to Amp. Still no sound. THe game I was loading ran before on same setup fine.
The Amp has no HDMI inputs. PJ does but that doesn't help the sound issue.
Console is never online so hasn't been updated at all but this shouldn't be an issue should it? I'm guessing the AV lead is faulty but don't have one I can swap in to check?
UPDATE:
Ran the console through the TV again but using component AV Lead and 2x RCA Stereo plugs and the sound worked so I guess it's an issue with the DSP-A1 amp. I'll have an extended fiddle with the amp.
UPDATE:
