xbox 360 HD-Drive + WinXP
Discussion in 'Computer Components' started by insomniak123, Sep 10, 2007.
  1. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    As title - is the x360 hd-dvd drive compatible with Windows XP?
    I've seen pics of it being plug n play in Vista but no such confirmation for XP
  2. pRot3us
    pRot3us
    Oct 20, 2004
    6,774
    +5,680
    Yes
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    In Xp you need to install udf 2.5 drivers (or run AnyDVD HD)
    In Vista you don't.
  4. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    nice, thanks.
    should provide a nice cheap way of being dual format :smashin:
    ooh just had a thought, it's too big to mount in a bay of a PC isn't it? worth a shot :rolleyes:
  5. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    Been there, tried that-proprietry brackets on the 360 drive that make it an ar$e to fit in a case.
    I went for the Toshiba internal drive for my HTPC in the end-much easier. :smashin:
  6. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    How much was the Toshiba though?
    i've got screwless bays so I'll give it a go i think, it should clamp it in if it's the right dimensions
  7. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
    £120 from here, excellent service and quick delivery. :thumbsup:
    I had a good go (& I've got a fairly large case), but it just wouldn't fit. The problem is that there are brackets fitted to the actual drive that are almost impossibe to remove without butchering it.
    I much prefer the internal drive as I don't like external devices, so I sold my 360 drive and used the cash to fund the Toshiba one. :smashin:
  8. jaymz
    jaymz
    Mar 29, 2005
    1,015
    Sunny Norfolk
    +60
    I though the xbox 360 drive was actually a Toshiba laptop drive unit and you could remove the drive from the case. I seem to remember seeing some photos on the web with it remvoe but can not find it at the moment?
  9. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    i'll have a search for that, would be very handy if true :smashin:
  10. Azzin
    Azzin
    Nov 5, 2005
    23,836
    +3,072
  11. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    think i'll just stick it on top of the PC :smashin:
