Xbox 360 from US - need to get chipped?
Discussion in 'Xbox Forums' started by psychocandy, Sep 6, 2007.
  1. psychocandy
    psychocandy
    Sep 4, 2007
    234
    If I buy one from the USA when I go there on hols, what issues am I going to face?
    Will I need to get it chipped to play UK games? If so, how hard is this and how much does it cost?
    What about the voltage difference? Or are they multi-voltage and just need a different plug?
  2. Anotherlimey
    Anotherlimey
    Nov 6, 2005
    6,113
    2
    Portsmouth
    +930
    Will you save ALOT of money buying a US machine? If so is the trade off worth the hassle involed in not being able to play PAL games and your voltage question, Some really good deals to be had in the UK with premiums and games bundles, Id buy a Uk one personaly :)
  3. psychocandy
    psychocandy
    Sep 4, 2007
    234
    $280 (£140) for a 360 core in Walmart...
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    Don't forget they add tax on top of that. They are only £180 in the UK now you know...
  5. runam0k
    runam0k
    Dec 16, 2005
    3,458
    London
    +217
    Chipping/firmware mods won't make the thing region free, so you'll have to buy US or region free games.
    As far as I know you can use a UK power brick with a US console.
  6. Trist
    Trist
    Nov 1, 2005
    4,662
    South London
    +1,261
    I'd agree with that.
    Not worth the hastle really. Sort yourself out a nice bundle with the games you want & just get one over here.
  7. Bushido
    Bushido
    Aug 17, 2006
    863
    Planet Earth
    +55
    There are no mod chips to change the region on the console and to be honest having to constantly buy NTSC games to play on it would end of probably costing you more in the long run and be a hassle.
    If I were you Id get a good UK bundle and don't forget with that you get a warranty as well which with the relaibility of the xbox is no bad thing.
    Just my two pence!
  8. tonyk79
    tonyk79
    Feb 24, 2006
    1,335
    63
    +192
    I was in Vegas in June and considered buying an Xbox HD DVD drive and although it worked out cheaper I didnt bother cause of the hassle with the voltage etc.. If the Xbox brick states 110-240v it should work ok in the UK with a change of plug lead but if you save £20 or so is it worth it?
  9. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    The HD-DVD drive is multi voltage and just requires a standard UK figure of eight power cable to be connected to the external power supply. The only issue would be the lack of warranty.
    The 360 itself however is voltage specific depending on the region it comes from and will require either a step down transformer or a UK 360 power supply.
  10. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    The discussion of piracy and the obtaining of software illegally and illegitimately is neither condoned nor tolerated here so please refrain from any such discussion.
  11. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    It's better for other forum members not to get involved and comment in this way as it can only lead to further argument, bickering and insults. If there is a problem the best thing to do is report it and let the mods take care of it if need be. Thanks.
  12. Sigismund
    Sigismund
    Jan 14, 2003
    5,535
    London
    +102
    Please do not ask for advice etc. on how to chip/mod XBox 360s - it is against forum rules. Thanks.
  13. TurquoiseShark
    TurquoiseShark
    The initial question was "does he need to chip his Xbox" - not "how do I chip my Xbox". Also, if it's against forum rules to talk about chipping Xbox's, why does the same rule not apply to hacking DVD's, which has a forum all of it's own!
  14. dan1979
    dan1979
    Sep 16, 2004
    3,539
    83
    +218
    I think they're referring to the now deleted posts by someone else that were quoted not the original question.
  15. SeeNoWeevil
    SeeNoWeevil
    Oct 14, 2003
    2,717
    +874
    A US Xbox over here is about as much use as a chocloate teapot.
  16. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    The comment was referring to the deleted posts and not the original post.
