W
wagger_12
i have just got a xbox 360 Elite but i had already had a xbox i was just wondering how do i get the old stuff off my hard drive on to the new 1! thanx
You need a cable that microsoft will supply free of charge for a once only transfer of all your data. Go to the xbox360 site where you can download the application form. Your need the serial numbers from both machines.
http://www.xbox.com/en-GB/support/systemuse/xbox360/console/datamigration-usingyourelite.htm
if they give it to you free of charge why didn't they just bundle it in the box?
I bought an Elite and never used any transfer cables.
Just a memory card and everythings tickety boo![]()
Just go into the memory option on the System Blade and copy onto the memory card anything you want to move to the Elite 120GB HDD.
Don't bother with XBLA games, as you can simply redownload them onto the new console anyway and they take up loads of space anyway!!
Important/Easy things to move are:
Gamertag/Profile
Themes
Pictures
Depends on what you're copying across.thanx the memory is the smallest 1 you can get.so will it all fit on or can i just copy i few at a time?
