Xbox 360 Elite HD question
Discussion in 'Xbox Forums' started by SHANE-BARKER, Sep 5, 2007.
  1. SHANE-BARKER
    SHANE-BARKER
    I am going to the states next week and want to buy a HD player for my 360 Elite , if i buy will it still work on my pal 360 ? i guess HD player is R1
  2. criticalmass
    criticalmass
    Feb 28, 2005
    548
    28
    Durham
    +40
    Yes it will work and its dual voltage too so all you need to do is get a uk plug for it. I did the same thing last december & bought mine while in New York.
    HD DVD is not region coded at the minute
  3. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,134
    Bristol
    +9,879
    The drive gets its region coding from the 360 so a US HD-DVD drive connected to a US 360 will be Region 1 for SD-DVD's but if you coonect a US HD-DVD drive to a UK 360 it will be Region 2 for SD-DVD's.
  4. m1ket
    m1ket
    Aug 24, 2005
    3,694
    UK
    +332
    HD-DVD has no region coding so no worries there, the 360 already playes normal dvd's so same region coding as before
