F
Frog Morton
Can anyone help?
I'm connecting my xbox360 to my HDTV using the component video cable. The 360 setup menu allows you to set its display type to 480p, 720p or 1080i. Trouble is, I don't have a clue which one of these I should set the xbox to. They all look the same.
I have an LG RZ42PY10X 42" plasma with 1024x768 resolution. So which of the 3 display settings should I set my 360 to. Can anyone help?
