Mitchsnake
- Joined
- Dec 29, 2007
- Messages
- 34
- Reaction score
- 2
- Points
- 7
I just got the hannspree 32" lcd tv from ebuyer, It is great using the hdmi ports for my pc and freeview if fine.
I am having a problem with the xbox 360 connected to it using the Red green and blue component cable. Cable is switched to hdtv but the picture is slightly blurry, not alot but enough to notice a difference.
The picture on my friends lg tv is crisp and crystal clear, mine however is not, it looks like it's standard def instead of hd. But the 480 setting does look even worse. I have tried 720p, 1080i and 1080p so far and still it is blurry, the colours are also too colourful and bright, changing the tv settings doesn't make it a right lot better.
I have ruled out the following;
.Not the cable, (It is a microsoft cable, also tried my friends)
.Not the console (tried friends console and is the same)
.Not the tv (friend has same tv, console looks same on his)
.Settings are correct. cable switched to hdtv and console in 720p,1080i or 1080p
.VGA cable looks fine, no blur, it is crisp and clear like HD should be. But hannspree tv's stutter when using vga so can't stick with that
I am thinking of returning this to ebuyer as faulty, even though my friends is exactly the same. I've come to the conclusion that it's just hannspree tv's that have this problem that they can't display properly through component.
Is anyone else having this problem with these tv's. The dashboard doesn't look too bad but is still noticable that it is blurred. When playing a game it looks quite bad, not as bad as SD but no where near HD quality.
I also plugged friends ps3 into the tv, played burnout demo and looked excellent, switched to 360, burnout was playin on tht at same time, looked blurry and colours weren't as good.
I have run out of ideas, so i'm thinking of returning it. Can anyone suggest anything else i could try. I have read hundreds of comments saying that 360 is excellent through component, it can't be a coincidence that mine and my freinds are faulty.
