Xbox 360 audio setup
redbullmaster
Hi i have a Panasonic TX32LXD600 with a dvd recorder set up to the component input. I can set the xbox though the vga but the problem is how to get the audio set up as the component audio is plugged in to it. Is there a device that will let me use both so i don't have to keep swapping leads over. On the back of the tv there are two sets of audio inputs both with left and right one set is there to set up with a amplifier and the other works with both component and vga. Seems to be the only flaw with a otherwise great tv. I could buy an amp and speakers (Sound Is great on the tv so don't want to spend more) or a Switch box but there must be a cheaper way to do this. Someone on here must have come across this problem before so any help would be great.
Richard
