Xbox 360 and Yamaha RX-V360 - Help!
Discussion in 'AV Receivers & Amplifiers' started by havoc1, Jan 19, 2008.
Tags:
  1. havoc1
    havoc1
    Oct 26, 2007
    5
    Hi, I have a Yamaha RX-V361 and speaker package (AVS301 I think) with my Xbox 360. I have the HD cable coming from the Xbox and the audio coming to the amp through optical in.
    The amp says Dolby Digital but I'm confused about which sound settings I should be running on the amp. If I am in default mode there seems to be very little sound through the central speaker, which doesn't sound right, especially on Guitar Hero 3. Which mode should I use?
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
    Is it like that with all sources i.e. DVD player, TV and so on? Did you run a speaker test etc. when you setup the amp? I would run it again and if necessary turn the centre speaker up slightly. I have no idea about which mode to use as dolby digital is what is output and is what I use for gaming.
  3. havoc1
    havoc1
    Oct 26, 2007
    5
    Hi - I know the centre speaker is working because it sounds when using Sky and also a bit on Bioshock, but it is very quiet on GH3 and when using the Xbox generally eg navigating around the Blades.
    Will try the speaker test again.
