Xbox 360 and windows media center
Discussion in 'General Chat' started by delboyuk2005uk, Aug 28, 2006.
  1. delboyuk2005uk
    delboyuk2005uk
    Dec 24, 2005
    3,580
    68
    St Helens
    +73
    Am thinking of getting this, BUT is it really worth it, can people point out exactly what it can do
    cheers!
  2. Kazuya Mishima
    Kazuya Mishima
    Dec 11, 2002
    1,429
    North East Scotland
    +65
    As far as I understand it, this allows you to use your xbox to view pictures, listen to music and watch movie files which are all stored on your PC. I suppose the main reason for doing this is if you have the PC in another room somewhere, but you want to sit in your lounge with your plasma and access all this stuff. The xbox 360 precludes the need for having a PC in your lounge if its just accessing media files you wish to do.
  3. jaybo123
    jaybo123
    May 23, 2006
    503
    Manchester
    delboy, i have it set up in the kids extension room with a toshiba 32wtl66 hd ready tv and it is great never have to burn disks again just stream movies on the wireless network i suggest gettin it mate
  4. h4rri
    h4rri
    Mar 22, 2006
    1,988
    +159
    I have it in the lounge and bedroom, you can stream movies etc [with VLC360 or TransCode] easily and the wireless is easy to setup :)
